2G POM Front & Rear Subframe Bushings
Gsx-Dude
Freelancer
176
295
Jul 7, 2015
Germany, Europe
For those of you whose old rubber subframe bushings are worn out, but new solid aluminium ones are a bit too stiff and uncomfortable..
I made this POM bushing set for your 2G front and rear subframe.
Made out of POM (polyoxymethylene) with an aluminium insert pressed in.
It has a better cushioning effect than aluminium ones, yet are still solid.
Prices are:
Front subframe set - $160
Rear subframe set - $160
..and to complete it, I offer these POM bushings for your rear diff, too:
https://www.dsmtuners.com/threads/2g-pom-3-piece-differential-bushing-set.519135/
Hey y'all just got done with the install not to bad. i used a 1/2" extension in the metal hole in the mounts and hit it with a BFH and they pop right out. Small ones have a metal sleeve so you can't bang them.
I used a 3/4 " socket and an 18mm socket with a control arm bolt and subframe nut to "press" them out. You can do the same to put the new delrin bushings in. I got them started with a hammer and used the bolt to press them all in pretty easy.
Subframe bolts 2x MR198095
Subframe nuts 4x MB242260
Washer for subframe bolts 2x MB303652
Dude makes a nice precision fitting bushing. Here's some finished pics from my talon.
I'm in for front subframe set! I wish I would have bought them all from you, but I mixed and matched with the solid VOLK diff bushings and the torque solution rear bushings...... smh.
Do you still have these available? Need a full set asap
