98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
Where can I get this for a good price.
dave99gst said:heres mine installed.
Defiant said:Be aware that some gauges will have depth issues with that pod.
vaboys2ndgen said:werd.. what the deal with the steering wheel does the cluster bezel get in the way of the steering wheel? that would suck owell just temporary anyways. thanks for the info tho mang
blackGSX2g said:Here is a pic I just took of what it would look like driving.
EDIT: the gauge is one of those smoke ones, so the car has to have the key in the ignition to have it light up.
Sounds like you over-tightened the top screws, and at the bottom where the factory part uses spring clips you need a couple of round-head screws and nylon inserts.vaboys2ndgen said:yeah i put it in all the way, and put the top two screws in so it was in fine. and then the bottom part of it wasnt even touching the dash... if that makes sense.
Um.... yeah. It replaces the original bezel.vaboys2ndgen said:the dual pod one doesnt go over the oem cluster correct.
