ttravis88t
- 107
- 13
- Jul 25, 2021
Jacksonville,
Florida
Hello, so my car (1997 eclipse 7bolt) is tuned with DSMlink and has a wideband 02 sensor from where I can view the AFR. Pretty much since I’ve gotten the car it’s always been quite inconsistent with the AFR. (Yes it is tuned as has been many times since I’ve bought it) For example, it’ll start up fine, around 14.7 and from there sometimes it’ll get very rich (low 13s) or sometimes very VERY lean (high 16s, sometimes even in the 17s or 18s). Same when I’m driving, cruising the AFR is sometimes between 15-15.5 and other times it’s in the high 16s and low 17s. Though under boost it does richen up nicely as it should.
Any clue what’s causing this? I have a new MAF, Both new coil packs, new spark plugs, to name a few.
Any help is very appreciated!
