2G Glowshift Gauge
1997DSMALEX
44
May 28, 2022
California
I just finished installing a Glowshift Gauge but it’s reading negative when the key switch is on but the car is off it’s at a steady -2,-1 reading but when I turn the car on it’s reading -16. Is their any calibration I have to do or faulty gauge?
Did you buy the gauge new? There is calibration paper work. There is a potentiometer on the back that you turn at key on engine off to dial it in. Glowshift is not the best, I installed a triple pod and couldn't get the boost gauge to zero out.
I contacted GlowShift tech support and after several emails they told me that I wouldn't be able to zero out my gauge because of my elevation which is around 5280ft here in the Denver area. So at key on I'm always -1.
Yea I got it brand new I don’t recall looking at a paper that said the calibration but I’ll definitely look again hoping that’s what it is if not well I learned my lesson with glow shift gauges
I guess they have better analog gauges. I don't remember exactly, pull the gauge and turn the potentiometer on the back either clockwise or counterclockwise with key on and see if it zeros out. You will need a small flathead screw driver.
Besides that the gauge is fairly accurate accounting for vacuum being higher than it actually is.
