Johnathan stlouis
- 0
- Oct 31, 2019
Alamogordo,
New_Mexico
I've driven my 1995 Eclipse RS 420A for about two weeks and it died on me out of nowhere, I've read the forums here and I'm still at a standstill I've replaced the fuel pump and fuel filter along with relays and a new crank sensor and I get no prime of the fuel pump when turning the key to on and no spark either ,could this be a fried ECU? all fuses and relays work and none are burnt out it just died while driving and has not turned back on since. It will crank but no fuel prime and no spark, I know the fuel pump works with a hard power line to it and will get to the rail while hardwired but was only to test it the pump was good,I don't want to have to hunt down the ECU for it if it needs a new one but I've done everything every suggestion I've seen except replacing the ECU...some one please help
