sleeperX2013
- 54
- 0
- May 5, 2013
Omaha,
Nebraska
So yeah guys thought I would share this with you. Cobalt ss turbo brembo monoblock calipers 30 minute upgrade. All you need is the calipers bolts and a die grinder with a small diameter metal bit. These calipers almost bolt directly on the 2g front spindles . You need to awl out one of the factory spindle holes for the factory 2g caliper bracket about an 1/8 of an inch and then they bolt right on. You can use factory rotors like I have pictured as of right now, but you have room for evo 8 / 9 rotors which I will be doing as soon as they arrive. I figured out all of this by mistake and am very pleased with the upgrade. It literally took me 45 minutes for both sides
