kiddsm95
- 154
- 0
- Mar 23, 2007
Ann Arbor,
Michigan
I have a couple questions for 2G's using DSM Chips. I understand that Jeff can specify an AFR into the chip, so based on my mods below what should this AFR be? Does running a chip with this specified AFR render WB02's & EGT gauges useless since the ECU will keep the car running as close to the defined AFR as possible.
Running the car with zero knock would be great, but if I do get knock what should I have the Knock MIL set to? What about the SAFC II, do I start over and set it back to 0% across the board and re-tune?
Mods:
1. E316G
2. Evo IX MR fuel pump (rewired)
3. Evo IX injectors
4. 3" TBE
5. Boosting 20 psi
6. SAFC II
Any help will be appreciated.
Mods:
1. E316G
3. Evo IX injectors
4. 3" TBE
5. Boosting 20 psi
6. SAFC II
