bzjosh
- 0
- Jul 21, 2016
Ketchikan,
Alaska
I have a 95 GSX with tons of mods. Currently I am experiencing issues with the GM 3 inch MAF sensor. As soon as i start the car i instantly show 0 HZ when im streaming it via dsm link v3. I have the GM 3 MAF option checked. I have the adapter that goes from the mas harness to the gm maf bought from ecm tuning. I have voltage to the maf and verified the ground is goodg. Also tested the signal wire back to the ecu. At this point I'm left to believe everything is pointing back to the ecu. I inspected the ecu but found no signs of leaking caps or burn marks. Also the ground strap on the ecu is good as well. I also swapped the maf with a brand new and still no luck. If i unplug it the car will run unless i give it gas obviously before it can't see how air is entering. I am a noob but am pretty good when it comes to mechanical issues and trouble shooting. Any help is much appreciated. Also i get a P0100 check engine code. Which is volume air circuit malfunction.
