Mark4g63t
- 294
- 5
- Jan 21, 2010
Minneapolis,
Minnesota
Just finished up my auto swap using a ratchet shifter and a shift kit. I have all forward gears but when I try to select reverse the car stalls immediately (like it hits a wall) almost as if something is locking up/ binding.
Anything I should be looking for? On the IPT install instructions it looks like the only valve that affects reverse is the N-R engagement which uses the stock spring. Did I miss something?
Thanks!
Thanks!
