georgethepainter
- 7
- Aug 5, 2022
Mt Hope,
West_Virginia
I’ve gone and put in a 2g 4g63t into my mighty max/d 50. It’s mated the original KM132 trans mission using the Eclipse flywheel and pressure plate and the trucks disc.
With the clutch disengaged (pedal up) and the trans in gear there is no vehicular movement. With the rear off the ground and the trans in gear I can spin the driveshaft, see the gears in the transmission spinning and hear the disc scuffing (slipping). There isn’t enough contact to drive the remaining components. What am I missing here?
Thanks in advance George the Painter
This is the flywheel I used. FWD Eclipse
