1. Join the Community!
2G 2g catch can design!!
Posted by bomishketi4, Sep 21, 2020
Please Support ExtremePSI
  1. bomishketi4
    bomishketi4 Probationary Member
    4
    Joined Jul 19, 2020
    usa, New York
    I have been very vocal regarding the lack of any 2g specific catch can options on the market currently. I had this idea of using JMF's small battery tray for a catch can holder, but could not seem to find any catch can to fit. After reaching out to a friend of mine who fabricates for a well known race team, this is what we came up with.
    We started with a 2g pc680 small battery tray from JMF. A lot of people use aftermarket intake manifolds, which sit much lower then the stock location. This is originally why I started using the pc680 tray in the first place. I did not like the pc680, especially when tuning when it requires multiple start-ups without proper run time for charging. After upgrading to a larger battery in another location (follow my build thread for more info) I had this mount being unused, and thought that this location would be perfect for a catch can setup.
    The can its self is approximately the same size of a pc680, with two -10 ports and breathers that clear the battery tie down. I opted not to use a drain on the bottom, due to how easily it can be removed from the battery tray.
    I could not be happier with the result - catch can is in a perfect location to clear intercooler pipes, and lines from the valve cover are relatively short (12-14"), and aesthetically I think it looks great. Eventually I will powder coat this wrinkly black to match my setup but here it is in its raw form.
    spyderdrifter likes this.
  2. 99gst_racer
    99gst_racer Moderator
    11,780
    942
    Joined Apr 5, 2003
    Coloma, Michigan
    Lets see some pics!
    Is it vented or sealed? What did you use on the interior of it to separate aerosol particles from the air?
    Street Build 7K  67
    1999 Mitsubishi Eclipse GST
    609.8 whp · 541.2 lb/ft · 2G DSM
    Loading...
    spyderdrifter, 2gjlc and chinola69 like this.
  3. spyderdrifter
    spyderdrifter Freelancer
    4,915
    544
    Joined Jul 11, 2009
    Fountain, Colorado
    Pics or it didn't happen...!!! ROFLROFLROFL Just joking, but would love to see it. Always thought about the same spot for the same reason.
    2K  2
    1996 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    2K  3
    1995 Mitsubishi Eclipse GSX
    2K  5
    1999 Mitsubishi Eclipse N/T
    automatic · 2G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
