- Thread starter
- #26
man_of_saturn
- 168
- 0
- Aug 31, 2002
Temple,
Texas
daren_p said:No you can run more then 20 psi with it as long as you have the proper supporting mods and you have some sort of logger and know what your doing with it. With race gas you could run abit more boost but again you need the proper supporting mods to do so. As for hp @ 20 psi, bench racing is just a guess. Every setup is different and it depends how well you can tune. I would think you should be in the 400 crank hp range but this could very quite abit, going to the dyno is the only real way to tell
I was going to go to Torque Freaks and have my car tuned an dyno, but then my car broke down and had to get it towed which cost alot. That took all my money so I decide to just play around with it my self.
But once I get the hose and clamps on I'll take it to the track and hope ones points and laughs at me.
Thanks for your info!
Again I'll keep every one posted.
I just drilled and tapped for a pressure fitting on my turbo outlet pipe and run that to the bottom of the MBC. The BOV is proven on this forum to respond better when it has its own dedicated vacuum source. Try running your WG actuator without the MBC in the picture. Do a little more troubleshooting, you're BOUND to figure out what all of your problems are..
