bsilverlake
- 1
- Dec 28, 2019
South Lyon,
Michigan
I needed to pull one of the heads to get a broken spark plug out. After fixing the problem I reinstalled the head, connected everything and started the car. It started with no problem, ran for about a minute then the battery light slowly came on and quit running. When turning the key to start it again, there was no power, no lights, nothing. I disconnected the battery, tested it, it is good (12.3 V) but when connecting the battery again I see the voltage drop from the 12.3 to 2 V in a matter of seconds. When I take the negative cable off the volts return to the 12.3. I am guessing a short somewhere? Can't figure why the car started then within a minute developed this problem.
Any help would be great.
Bill
Bill
