Please Support STM Tuned
2 week old intermittant SRS light, now getting annoyed
Phoenix_RsX
324
Jun 28, 2002
MarylandUS
When the light first came on, I found that the fuse was blown. No big deal, I changed it and the light went away. Well now for about two weeks now, the light comes on, turns off, and has stayed on.......however my fuse isn't blown. what next?
The ABS system is just like the ECU. It has it's own controller and the ABS light, when on constantly, means that the ABS controller has ran a test on a circuit/system and the system failed the test. The codes can be retrieved with a high end generic scan tool or a dealer scan tool. Chances are a palm, dsmlink, autozone scan tool will NOT be able to access the ABS controller for code retrieval.
Once you have this code you can begin to trouble shoot the system. Until then it's a matter of guess work. Wheel speed sensor, broken tone ring on the hub, abs pump failure, abs module internal failure, or any number of things.
Doug
