2 Problems/Questions!!??
talontedtsi1995
140
Sep 14, 2005
reading, Pennsylvania
Alright, I have a 1996 Talon TSI FWD with a BOV,intake, walbro 255lph fuel pumpp, big T-28, 2.5 inch DP, cat delete and 3 inch exhaust...I am running stock boost controller/settings, if i hold the throttle and don't wot it will hold boost around 13-14psi, if I go WOT it hits 15-16 psi and will cut in and out and sputter? I boost leak tested it already and fixed all leaks except for one very slight leak around the idle control screw, problem is, I unscrew the idle control screw but it wont come out of the hole, how can i get that out? also what could I do to fix it? and do you think that very little air could make my car run that bad at WOT? any advise or help would be great, thanks!
UPDATE: I changed my oil, fixed the idle adjust. screw, and new spark plugs, car runs good now no sputtering, but my check engine light has recently went on about a week ago so i got it checked and it said something with an idle control sensor and engine vaccum leak etc. I couldnt find anything called an idle control sensor, I checked every vaccum line all seem to hooked up and hooked up right, the car constantly idles around 1,500 RPMs now..any ideas? help would be great..thanks
thanks for the reply, I will check that out tomorrow and test it now that i know where it is and see if it is my problem, I will let you know what happens, i don't like check engine lights nor my car idle going different RPMs everyday, thanks
  • For sale 4G63 91-96 Auto Transfer Case
    91-96 Auto Transfer Case $200 + shipping and PayPal feesYou must be registered to see...
  • For sale 2g 2G LSD Auto Rear Differential
    2G LSD Auto Rear Differential $300 + shipping and PayPal feesYou must be registered to see...
  • For sale 2g 2GA Auto AWD Intermediate Shaft
    2GA Auto AWD Intermediate Shaft $225 + shipping and PayPal feesYou must be registered to see...
  • For sale 2g 2GA Auto AWD Transmission
    2GA Auto AWD Transmission $750* pick up in 08080 NJ or you can send a freight carrier and I...
  • For sale 2g 2g lsd Auto rear (JFH)
    2G AWD LSD Auto Rear
    • pottersgst
