1. Join the Community!
1G 1Ga Antenna, Options In 2020?
Posted by Car Cannibal, Feb 10, 2020
Please Support Rix Racing
Please Support VR-Speed Factory
  1. Car Cannibal
    Car Cannibal Proven Member
    382
    6
    Joined Jun 7, 2003
    Chicago, Illinois
    So my antenna has been a disaster since a car wash bent it, I just pushed it in and it's been ok since but the top broke off. Recently it's bad so...
    Those stubby rubber ones, they fit?
    (Link won't work)
    What's out there?
    I have the big factory black one that you can pull out and collapse (don't remember if it was powered but I don't think so).
    Thanks
  2. Widgmaster
    Widgmaster Supporting VIP
    54
    114
    Joined Aug 24, 2018
    Sarnia, ON, Canada
    There are many aftermarket antennas out there . I will add a link to one site that carries an antenna that is a match to your car.
    https://www.crutchfield.ca/p_12044U105/Replacement-Antenna-for-Chrysler-GM-Honda-and-more.html
    You may even decide to get a power antenna .. If your radio does not have the remote wire for the antenna power just pick up a 12V power source and use a single pole toggle switch to power it up and down. This way when you go into a car wash you can lower your antenna so it don`t get broke
    46  1
    2002 Dodge Dakota Extended Cab
    rwd · automatic · Misc Vehicles
    186  7
    2001 Mitsubishi Eclipse Spyder GT
    fwd · automatic · Misc Vehicles
    Loading...
  3. ist dwa
    ist dwa Proven Member
    273
    109
    Joined Nov 5, 2009
    Centerville, Ohio
    Ive found the stock antenna to work best, if somebody has real world experience otherwise im listening. What i do is use the oem power one minus the power stuff, pulling it up by hand about 12" seems to be good. If im racing or at a photo shoot i push it back down, if i'm going on a serious road cruise where i need signal I'll pull it all the way up.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
