1g transmission
As long as you have a matching transfer case it will work.
Depending on whether it was an early or late 91, the stock transfer case might even work. The 93 will need a 23 spline transfer case. The 91 will have either a 22 spline or a 23 spline, depending on if it was an early or late model.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
