davetheman81
- 163
- 0
- Jun 16, 2010
randolph,
Massachusetts
i recently had someone replace my tranny in my 92 tsi awd and they installed a 90 tranny with 90 t case. 20 miles later the t case seized and caused the rear end to snap and axle. I dont no if the person forgot to fill it, or if it had a bad leak, or something. So i got another known good t case, replaced the seal and had it installed. We noticed after we drove it and it sat over night there was a 4 inch spot on the ground of fluid from the t case. The installer said he may have over filled it and thats why the spot was there, so he drained it and re filled it properly, now after i drive the car and let it sit for a day i notice either a half dollar or 3 inch sized spot under the t case and a drip right were it meets the u joint. My question is would this probably be due to a bad yolk? Since the t case is good with a good seal im guessing it has something to do with the yolk or u-joint, since my car has already had the recall, is there a fix for this or should i bring it to a dealer and have them do it again, any idea of what it will cost?>
