1g swap on automatic
KeelesKustome
882
17
Dec 29, 2007
Waverly, Tennessee
okay guys i have my engine in, and it won't let me start but i just realized,
i have an auto with the kiggly adapter.
i can't take it out of park. i am pretty sure i put the kickdown cable under the fuse box, right back where it was at originally.
but i am now thinking that maybe it's not in the right spot or something isn't, thus not allowing me to start or even put it in any other gear with battery connected or un connected///
please help with a lil insite.
Your posts a bit vague. You did a 6 bolt swap, and therefore you had to buy a kiggly adapter to mate the two right?
Kick down cable? You mean shifter cable? You can't move the interior shift handle out of park?
yeah.
i lossened the 10mm bolt, and pushed the gear selector all the way frontwards and re tightened the bolt.. now it seems i have every gear back...
that was strange.
1/8 in out of adjustment will make it sit inbetween every gear. You probably have the cable sitting differntly than before is all.
Glad it was an easy fix, hope that was it.
Sent from my Droid
