black97spyder
- 704
- 23
- Oct 13, 2012
independence,
Kansas
Okay so about 3 months ago when i was in the middle of buying parts for my engine rebuild I came across a unused set of forged Wiesco 8:1 and scat H beam rods for $450 online.... The guy said that they were for a 7 bolt, standard bore and ready for install!! So i made a road trip and went and inspected them and they looked great! Jus minute surface rust patches Here and there on the rods so i bought them.... First off, they ended up being .020 overbore so i Thought no big deal, I'll just bore my block and go on with the install. So i bored my block and found out the guy I got them from Had 3 out of 4 rods turned around backwards. Once again dumb me Thought no big deal, so i turned them around so the bearing tangs were facing the correct way. Being that i Thought I had everything ready for my build to begin, I went ahead and put my ARP main studs in and dropped my crank in...... Now I started to put the pistons in, compressed the rings and stuck the first one in to find out that my rods are too wide for my 7 bolt block!!! .... So I found out once again the guy I bought them from deceived me yet again and they were 6 bolt rods Not 7 bolt rods
Situation is that i am now broke otherwise I would just buy a set of 7 bolt rods and sell the 6 bolt ones
Is there any problems that anyone can forsee me running into by simply swapping the rods to 7 bolt rods? Are the wrist pin sizes the same between 6 bolt and 7 bolts? I'm trying to solve this massive headache as easy and cost friendly as possible.. What options could I do to make the 6 bolt rods work with my 7 bolt crank??
ALL would be greatly appreciated! Thanks, Matt
