Please Support STM Tuned
1g rod bearing wear. HELP!
rtincher22085
140
Aug 17, 2010
Rockland, Maine
Is this normal bearing wear these are rod bearings. Had some sort of knocking pulled engine to see this I need opinions and the clearances were .003 this engine only had 300 miles on it. The crank was polished and cleaned before install. I did everything right so whats the issue.
Doesn't look to awful bad.
But only 300 miles hmmmm
Gonna forward this to a buddy to check out.
If there is no definete answer by then ill let you know what he said.
thank you very much i'd like to know ,I'll be p@#$%d if pulled my engine for a piston slap issue I have JE pistons
Assembly lube was used, and the crank was polished. It didn't need a regrind and the right bearings were used. Caps were torqued to 42 lbs according to the eagle instructions
