BLockDsm
- 59
- 0
- Aug 4, 2005
western,
West_Virginia
I purchased a 1990 talon tsi awd 106k miles this past Sunday.Upon seeing the ad it stated that it had some issues and the kid didn't have the money to fix the car. So anyways I go to check out the car and I pop the hood check the oil and the radiator fluid looks good so I say Ok start it. The car had a very hard time starting and wouldn't take throttle but overall it sounded good and with a price tag of 1200 and all the goodies it came with(2gmaf-evo8 injectors exhaust, ecm link and the fact that the body is 85 percent flawless) I said ok cool let's do it . I trailer the car home and pop the hood. Well I knew it had a 2g maf installed and that obviously it had stock injectors installed since he gave me evo 8's with it . So I then notice one of the injectors was unplugged . Well I plugged it in and started the car.. no change.. So I then did it with the others and bam the idle became even worse . so at this point I change out the injectors with the new evo8's and bam the idle evens out much better. So I pull the spark plugs and they are burnt to a crisp Also I notice oil on top of the piston. Which I find odd since it isn't smoking at all? (except wot then its black smoke) so I go to the parts store grab a set of plugs put em in and bam no missing idles perfect .Only thing now is the car is very sluggish it will boost to only around 7psi (kind of spiky) and will only go to around 3k rpm then just like it hits a rev limiter 2second gear fine until around 3k and 3rd gear the same other than that it drives fine.. It just feels like that commercial where the guys on the interstate with a anchor attached to the back Now that I can drive it I am going to take it to get the cell checked, do a boost leak check and also do a compression test as well tomorrow. I know those things will tell me allot more but I was just wondering what you guys think or if anyone has had any similar probs or anything else I am missing. Worse comes to worse Ill slap a new engine in it because I did buy it knowing it had problems and I bought it as a project car. Thanks in advanced!
Also 1 time when I was kind of easing in the throttle in second gear it"POPED" out of the sluggish ness and boosted like it should for about 2 seconds then bam back to slug mo-bile. I checked the upper i.c pipe and it had a pretty good bit of oil in it but i may be over exagerating but I stuck my fingers in it and the came out coated fairly well.
