1g manual rack swap. read everything I could find..need imput
Siral3x
299
Mar 2, 2006
Ludington, Michigan
I found a 90 something 1.8L Eclipse with a manual rack.
What are all the parts I need to pull off for a swap on my 90 GSX??
I heard I need some brackets??what are they??how do they look like??
Anything else??
Tie rods are diff?
All you need is the rack, rack mounting bushings, and the mounting brackets. There are 2 brackets that hold the rack in the car. Each bracket has 2 bolts and the bushings are wrapped around the rack itself. It will be self explanitory when you climb under the car and take a look.
  • For sale 4G63 TD04HL turbo
    TD04HL turbo off a Mitsubishi RVR. This is a dsm bolt pattern turbo and is slightly smaller than...
    • MichaelSuch
  • For sale 1g 92-94 eclipse fender/door/quarter trim
    92-94 eclipse fender/door/quarter trim piece set. All clip towers intact. Passenger side quarter...
    • MichaelSuch
  • For sale 4G63 2GA AWD Auto Transmission
    2GA AWD Auto Transmission $750*** Pick up in 08080 NJ, you can also send a Freight carrier for...
  • For sale 4G63 70mm s90 throttle body - rebuilt
    Up for sale is a lightly used and correctly rebuilt 70mm s90 throttle body. This will fit all...
    • MindBlowin03
  • Wanted 4G63 1G JMF Intake Manifold
    Okay condition. Pm me with what you have.Ty.
    • oldkidken
