BerettaDan
- 45
- 7
- Jun 19, 2009
Philadelphia,
Pennsylvania
Does anyone still make a 1g converter? I can’t find anyone that sells them.
Ive had really good luck with the stock 1g converter in my car. Last time my trans was out I took the converter to a local converter shop and had them cut it open to clean and inspect it. I had them tig weld the fins and replace the bearing. The stator was stock and left alone since it was working good with my setup. It was around $200 to have that done. Its held up good so far and my car also touched 8's with it.car-cannibal how do u like the strokinator? Did you or know anyone that ran the Draginator 9.5”. Does anyone know what kind of power a stock restall can handle? I’m new to the auto world and this will be my 1st auto car so sorry if I repeat myself. I plan on being around 800 plus hp so just trying to buy once. I’m going to contact Mike to get his input thanks everyone
was this on a completely stock converter or a restallIve had really good luck with the stock 1g converter in my car. Last time my trans was out I took the converter to a local converter shop and had them cut it open to clean and inspect it. I had them tig weld the fins and replace the bearing. The stator was stock and left alone since it was working good with my setup. It was around $200 to have that done. It’s held up good so far and my car also touched 8's with it.
stock.Blue90d3w
