Please Support RTM Racing
Please Support STM Tuned
1G engine 2G Ecuflash coil order
YoYo_4G63
187
3
Sep 5, 2008
Carolina, Puerto_Rico
Got a question, I have a 1G engine (sensors etc) but with a 2G Ecu flashed. The car doesn't want to start, do the coil order should be changed? The guy in charge of the tuning etc says i should change it from 3214 to 1423 but didn't do anything.
injectors are connected per ecu pin 1 to 1 etc
if its a 98+ ECU in a 1G then you do not need to swap plug wires. The cam signal might need to be inverted though but the car will start.
