1. Join the Community!
1G DSM wont start
Posted by 1991eagleawd, Jun 24, 2019
Please Support Morrison Fabrications
Please Support Southbay Fuel Injectors
  1. 1991eagleawd
    1991eagleawd Proven Member
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    Hey guys, its been a long time since I last posted. But here goes....
    I recently finished body work and paint on the 91 talon. I had not driven her in 3 years. ( except around the block to break off rust on rotors) So I wanted to take her out for a good ride. she was driving beautifully and strong for the first hour. On my way home I decided I was gonna unleash some power. Upon putting into 3rd gear I heard a clunk and smelt my clutch.
    I immediately dropped into neutral and coasted to a stop on the side of the road. I felt like my clutch pedal was half the pressure it was, and I could not put it into gear. I took a look at the slave cylinder and it was doing its job and no leaks. I could feel pressure build up if I actuated the clutch with car off, so I decided to start it in 1st gear to get her home.
    Upon arriving home, I noticed I was able to change gears again and that the clutch felt 70% back to normal pressure... I decided to let it sit over night before i looked into it further. The next morning i attempted to start it with no luck.
    I have a battery volt meter that was showing 10.9 volts.... Enough to crank, but all I got was a click (starter i'm guessing) and voltage drops to 7v. Before this incident the battery voltage was 13.9-14.2v while running.
    So I hooked up the wifes SUV to jump start, and it would only give me 11.3v with a running vehicle attached to the Talon, and again would drop to 7v upon attempted start. So I removed the battery from the Talon and hooked connections directly to the jumper cables, same thing. I pulled my wifes good battery and dropped it in the talon with same results. No crank, just a click and very low voltage.
    I checked starter connections.
    All fuses are good. (from looking, not using multi meter)
    Grounds are good.
    Clutch engage start thingy under dash/pedal is unplugged for no depressed clutch start.
    Now I know this seems like two different issues, but I think they are linked together somehow.
    Any input is greatly appreciated. Please excuse the mini book write up. Thanks in advance.
  2. ThunderChild
    ThunderChild Supporting VIP
    2,430
    639
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Starter sounds like it's internally shorted and sucking power maybe.
    Clutch issue sounds like a TOB or pressure plate finger issue.
    Street Build 106  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    229  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 743  7
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    Street Build 942  1
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
  3. 1991eagleawd
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    so im pulling off the tranny I guess....??? :( thank you for the reply.
  4. steve
    steve DSM Wiseman
    12,717
    501
    Joined Feb 3, 2002
    St. Charles, Illinois
    If I remember correctly, pulling the starter is two bolts and the two electrical connections.
    Remember to disconnect the battery before you start working. Welding a wrench to the frame tends to be too much excitement.
    3K  0
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
    ThunderChild likes this.
  5. ThunderChild
    2,430
    639
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Correct and yes excellent idea, I've melted a couple wrenches in my day by being ignorant or in a hurry.
    @1991eagleawd pull the starter and have it tested, also double check the connections and make sure they're all clean and getting proper signal/voltage. There should be the main power feed, directly from the battery to the starter solenoid, start signal from the key with a spade terminal (12v+ with key in start position only), and a ground cable going from the firewall/battery directly to one of the starter bolts. The ground is important for current path and keeping resistance down, I've seen alot of people remove it without knowing the consequences.
    At the very least drain the fluid in the trans first to check for metal shavings. If you find a significant amount (post some pics) the I'd recommend pulling the trans and opening it up to look for the issue.
    It sucks, but whatever the issue it might still be salvagable.
    Street Build 106  3
    229  8
    Street Build 743  7
    Street Build 942  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  6. steve
    steve DSM Wiseman
    12,717
    501
    Joined Feb 3, 2002
    In too small a space... Forgot the second half of that thought :)
    3K  0
    manual · 1G DSM
    Loading...
  7. 1991eagleawd
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    Thanks for the replies! Imma dig a bit deeper n get back to yall.
  8. Vegas smith
    Vegas smith Proven Member
    2,500
    1,140
    Joined Dec 2, 2002
    Houston, Texas
    It's certainly possible you have two separate problems if you haven't really driven the car in 3 years. It sounds like the battery is dead.
    Street Build 3K  10
    1993 Eagle Talon TSi AWD
    Loading...
  9. 1991eagleawd
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    What about the fact i cant boost it?
  10. Vegas smith
    2,500
    1,140
    Joined Dec 2, 2002
    Houston, Texas
    I'm not a professional or diagnostic wizard, but my last battery died and would not take a jump and voltage would drop even further when I tried to crank the car. Can't hurt to look into it.
    Street Build 3K  10
    Loading...
  11. 1991eagleawd
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    I tried a known good battery. Same results.
  12. Vegas smith
    2,500
    1,140
    Joined Dec 2, 2002
    Houston, Texas
    They could have both been bad (kidding)
    Street Build 3K  10
    Loading...
  13. 1991eagleawd
    83
    Joined Jul 5, 2011
    toronto, ON, Canada
    So i found that if i remove the positive wire off the battery that goes to i think the alt (haven't traced wire yet) . I don't get a huge draw reading at the battery terminals.
    So bad ground on the alt?
    Would a bad alt draw from battery with no load? I just installed this GM alt last year... Imma check grounds again...
    I noticed as well that even with battery connected. With the draw wire off (alt)
    when i put key to on pos the battery goes right too 2-6v. Turn key off .... Wait a few seconds and hear the relay under the dash go cluck and bam 11v back on battery.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory WheelWell.com White Shed Speed
