JdawgDSM1G
- 35
- 1
- Sep 6, 2011
Easton,
Massachusetts
Hello all, im new to the forums here. ive had this issue with my race car for quite some time now. its been so frustrating that i had stopped bothering with the vehicle altogether for over a year and actually tried selling it a couple times. about a year and a half ago i installed a fresh stage 3 tranny from TRE and an act 2900 kit with my factory lightened and stepped flywheel. i put the car together only to find that the clutch wouldn't disengage at all. i then proceeded to pull the transmission back out and check over my work. i added a larger washer for my pivot ball shim. installed a brand new oem clutch fork. brand new ACT throw out bearing. and put it all back together. once again no clutch disengagement. so i started with the hydraulics. put a brand new master and slave and a stainless clutch line. bled the crap out of it and still nothing... i then tried the crappy extended slave rod as i was getting desperate, guess what. nothing.. i got so disgusted i let the car sit, until last week. i sat and tried to figure out what else could be wrong and finally decided to pull the clutch pedal assembly. turns out it was quite worn where the z bar connects. so i had shep rebuild it. i have now installed the pedal and boy did it help but i still cannot shift the vehicle in gear while its running. i have the master fully extended as far as i can go and the slave seems to be moving pretty darn good. so here i am hoping a fellow dsm,r can help me with my craptastic situation ...
jdawg
jdawg
