Anfurnyy
Supporting Member
- 639
- 706
- Jul 4, 2020
Rapid City,
South_Dakota
*EDIT*
As I'm updating this build, it seems that this is turning more into a story than just a build. I've updated the title to reflect this, I suppose. This build is really going to showcase the real life issues behind building / working on a DSM and the problems, solutions that other might run into as well. Hopefully this will help people someday. Enjoy
Oh man where to start.
i Bought this car off a buddy of mine that had it for almost a decade. With 155k miles, He parked it due to it jumping timing and bending valves. It sat covered in a garage for the last 7 years or so, with the head off and tons of bolts and odds and ends missing.
i started off by rebuilding the head. I did some research and found a few things that were highly recommended. So i ended up with some Ferrea Oem size valves, Kiggly HLA, Stock cams and gears, GSC Zero tick lifters. I bought some evo 8 rockers from a facebook group but they were trashed when i got them, so i moved back to some dsm rockers. to summarize i got the car running but it the transfercase was bone dry due to some leaky transfer seals, so i parked it again and while i was doing that i decided to make the switch to Speed Denisity and change the turbo setup a bunch of times, and finally Landing on a GTX3584RS.
i have a TON of pictures so ill be updating this post in the near future with the process of the rebuild and the current upgrades going on!
Here's a couple pictures of what the car used to look like and how it was when I received it
