- Thread starter
- #401
Anfurnyy
Supporting Member
- 652
- 719
- Jul 4, 2020
Rapid City,
South_Dakota
I'm actually using 2 of the outputs from the ISC motor to control 2 separate fan relays since those wires are already on the passenger side and are easier ran to the fans.Gotcha. You can use the egr for fan control if you'd like. The expansion harness has a 5v out that should give you all the 5v power you need. If you need a 12v relay board then something like this would be perfect:Big Dog 3 Distribution Block
The Big Dog 3 distribution block. Has three inputs (high current battery positive, high current ground and low current ignition positive trigger(from a ignition switch). Module has a built in 70 amp relay for the Ignition power outputs. So the Ignition trigger input only requires a small low...leashelectronics.com
Ill keep that it mind. Right now I think I might just use a small Busbar since I've only got the can relay being powered by 12v.
