99gst_racer
Moderator
- 11,976
- 1,542
- Apr 5, 2003
Coloma,
Michigan
The angle might be too severe on a factory rearend. But you'll have the ability to change the position of the pig and angle of the pinion when you're setting up that solid rear, and you can correct any misalignment that prevents good use of a 1-pc shaft.
Another option is a 2-pc shaft that utilizes the front carrier bearing. Although, that's going to cost alot more than a 1-pc shaft.
