nightracer91
- 413
- 5
- Feb 27, 2006
Fort Wayne,
Indiana
So with a Holset build in the works, I have been thinking driveline in the back of my mind. With my second 3 bolt rear end in the car, I think I have decided to do something out of the ordinary and build my AWD with a solid rear axle. I see many Ford 9's and 8.8s and even one Toyota but I was handed an axle assembly the other day that I think might be pretty cool to try and make work. It is out of a late 80s to early 90s 4WD Mighty Max or Montero. It has a hub to hub width of 55" which I believe is slightly too narrow compared to the 1G width. Someone please correct me here. However, with a 3.55 option available (out of a 2WD Mighty Max) and a pinion flange that fits directly to the factory 1G driveshaft rear flange. Why not see if I can make it work? One down side is the 6-lug axles but those can be machined and redrilled for the 5-bolt pattern. Not to mention, the bearing set up on these axles is very smart in regards to serviceability and overall funtionality. I am curious why this has never been brought up or attempted before? Is there something I am missing that is going to keep this set up from working? Obviously 4-linking the axle is the only way to go. Of course somebody will think I am wasting my time, or I can start looking into some Ford axles as they are quite plentiful in my area (all these mudding 4-wheeling trucks rolling around). I just think it would be neat to see a Mitsu still having all Mitsu parts
