Morphius
DSM Wiseman
- 1,895
- 65
- Jun 9, 2003
M-Town,
Michigan
Looking for someone who has some experience with the 1G AWD automatics.
1. Does the 1G TCU output error codes like the 2G's can?
2. If so, how do I access those?
3. If not, how would you diagnose the following:
91 AWD GSX. 1-3 gears work great. Shifts solid. Flip the switch to allow it to use the OD and it neutrals out. No go. Turn it off and zip I'm off.
4. Is the above condition typical for a OD clutch pack that is bad?
5. Anyone had this condition and changed the clutch pack and it solved the condition?
6. or What did solve this condition?
7. Which connector on the tranny harness is for the OD? We had to splice a connector on it before we installed it. Just want to be sure we didn't mess something up there.
Thanks.
Thanks.
