Please Support Kiggly Racing
Please Support STM Tuned
For Sale 1999 GSX, 62K Original Miles
crazytsiawd
132
6
Dec 12, 2006
Edmonton, AB_Canada
Just seeing if there is any interest in a fully built dsm part out, bearings racked up in the shortblock in cylinder 1, don't have the time or energy to rebuild it, id consider it selling it as a whole as well.
1999 Eclipse GSX, Fully loaded.. (Last year these were made, super rare)
Clean Title, No Accidents
62000 Miles on speedometer
Car was imported in 2009 from New Mexico usa, has never been winter driven.
The Bad -
Drivers side door handle needs to be replaced, have the part have yet to put it on.
Paint fade, some areas do need some paint work.
Bearrings shot in short block.
3in thermal exhaust
Custom downpipe
Aeromotive fuel rail
Aeromotive afpr
Walbro 255 fuel pump
PTE 880cc fuel injectors
Rewired Fuel Pump
Custom intake
K&N Air Filter
FP HTA GT3582R
FP exhaust manifold
FP o2 housing (recirculated)
Tial 44mm MVR wastegate
Turbonetics godzilla bov
Flex a lite slim fans
Koyo aluminum radiator
Dual oil catch cans
Magnus SMIM with ports
Spearco Fmic 12x24x4 w/ short route piping
Aquamist HFS3 direct port meth injection
Custom meth injection tank in the trunk w/ fill port
1g 63mm throttlebody
Optima redtop w/ remote posts
6 bolt 2.3 stroker
eagle crankshaft
wisco HD pistons
eagle rods
.20 over
acl bearings
skunk2 cam gears
crower 272 cams
crower Valve Springs
crower Retainers
Supertech black nitride valves
Arp head studs
Cometic head gasket
Greddy Timing belt
balance shafts removed
vi-pec v44 stand alone ems
3 Piliar gauge pod
2 Dash gauge pod
aem oil pressure gauge
aem water temp gauge
aem boost gauge
aem wideband gauge
aquamist methanol gauge
B&M short shifter
ACT 2600 clutch w/ kevlar disc
Manual boost controller
Fidanza lightened flywheel
18x8 ASA Wheels
Ground Control Coil Overs
Tokico 5 Way Adjustable Shocks
Brembo evo8 brake kit, galant knuckles ect
hawk HPS brake pads
15mm wheel spacers with extended studs
rear camber kit
poly urethane motor mounts
Pioneer double din headunit, nav ect
Hifonics Brutus D-Class 1500W Amps x2
Sony X-plode 6x9s x2
Sony x-plode 6.5 x2
8inch Sun visor TV Screens x2
Hifonics AS12 Subwoofers x2
Custom Made Sub Enclosure
Custom Made Amp Rack
Power Acoustik 20 Farad Capacitor
Stinger Fuse Blocks x2
Stinger Ground Distribution Block
Stinger Wires
Stinger Battery Terminals
Retrofit hid headlights acura tsx lesnes ect
Evo 8 Momo Steering Wheel w/ airbag
Clear Corners
Injen polished fuse cover
Injen Brake fluid cover
Injen polished sparkplug cover
Injen Upper rad hose.
so much more that im not thinking of, this is just off the top of my head.
