95REGF150
- 447
- 242
- Mar 7, 2012
Elk Grove,
California
The exhaust is still being fabricated. The exhaust is getting ran all the way out the back to the rear bumper. No side exits.
I think his point was if you did a muffler and side exit it would flow much better than that flat section you had to do to get under the dropped suffrage.
Good to see all the progress and it finally sitting on the ground. A lot of work you guys are putting in. Props to you guys for the follow through.
Constructive criticism wise though with the subframe drop/ body lift I don't think it will ever sit low enough again to look factory. But its not going to be as bad as I first thought when I saw those spacers.
