freshlane
- 536
- 13
- Sep 4, 2006
Chicago,
Illinois
1998 Eclipse GST w/ 106k miles. Intent was building as 'track' vehicle. I have ALL receipts for ALL work performed and purchases including brand new transmission. Vehicle used Ecmlink with sd conversion. No start since 1g cas installed.Will need tow.
SOLD
Note;
Uses push start button
Fans activation via switch panel
No power steering, removed
Will need AC compressor belt for ac use.
No radio
Battery relocated to trunk
2 exhaust manifold studs broken
Some strut tower rust & rear qtr rust
No driver side carpet. Sound deadening applied.
Slight leak at coolant crossoverpipe
New-in-box parts included w sale;
14b 16g SS oil feed line kit
14b 16g 10AN oil drain adapter
2x new front wheel hubs
ARP head studs
Topline complete engine, upper and lower, seals and gaskets set
Gates Economy Complete Timing Belt Kit with Water Pump
Ohm racing 1g cas harness
1g green top cas (not new)
Alternator & wiring, Starter, power transistor unit, thermostat, radiator hoses, idle speed controller, new turbo gaskets, and coolant flush recently performed/serviced.
Installed;
Tubular turbo manifold
Precision SCM 5031e turbo (blown t25 turbo inlcuded w sale)
MAP 7CM gasket w/ bolts.
1G DSM cam angle sensor
GM IAT
Omni 4bar MAP
ECM Tuning speed density plug-play harness
Aluminum intercooler piping
Aluminum intake w/ KN filter thang
Forge blowoff valve
FueLab "515" Complete Fuel Pressure Regulator Kit w/ Gauge (Version 2)
FueLab "818" Fuel Feed Upgrade Kit (OEM Hardline to Fuel Rail)
JayRacing coil-on plug setup
Walbro 400lph fuel pump installed, newer Walbro 255lph pump and 2nd module/hangar assy included.
EGR blockoff
2 Mishimoto radiator fans installed, new 16in Mishimoto + ebay 12in fan also included
Aluminum coolant overflow
G-Plus radiator hoses
Tanaka steering wheel w/ release hub + Ebay steering wheel w/ release hub
Roll bar
Offname 4 point belt harnesses + sickspeed harness
3in straight piped turbo back exhaust
Mods-EMS & Logging:
ECMlink V3, ecu, & cable + factory 1998 GST non-eprom ecu (2 ECUs)
Equus Boost guage
Volt meter
Dial-A-Boost Electronic boost controller
Mods-Drivetrain:
(re)Built transmission (Tramcar 2020 - upgraded clutches w complete overhaul 12/12wty)
Stalled torque converter (Tramcar 2020 12/12wty)
ForcedFour Shift controller
Outlander Ralliart paddle shift assembly
Torque Solutions Solid motor mounts (front and driver).
Mods-Handling:
FR & RR Strut tower bar
Axis Se7en wheels (one center cap missing).
1/2in wheel spacers
Megan 2in lowering springs
Front lip and fender flares are installed
Call/Text/PM 773.690.3174. $2,400 Takes it. Ran and drove. No brainer. Clean title. No garage space or time is only reason for selling.
Cash/Crypto (preferred)
SOLD
Note;
No radio
ARP head studs
Installed;
GM IAT
Omni 4bar MAP
Forge blowoff valve
EGR blockoff
Roll bar
Mods-EMS & Logging:
Equus Boost guage
Volt meter
Mods-Drivetrain:
Mods-Handling:
1/2in wheel spacers
