98GSXin
- 930
- 0
- Jun 2, 2010
Santa Clara,
California
*Sold as of 10/14/12*
I finally put it up. This isn't a decision I took lightly or rushed into. It was planned and well thought out. Not my favorite of options, but it is basically necessary at this point in my life. Here's the craigslist ad:
New Link
http://sfbay.craigslist.org/sby/cto/3212913582.html
It's not like I'll be gone forever. Maybe I'll find a cheap 1g beater to help keep the dsm fire burning afterwards. We'll see. Let me know if you have any questions or know someone looking for a shortcut to a seriously fast and awesome car. Thanks.
Per outlawdsm's request, full disclosure:
1998 Mitsubishi Eclipse GSX: Clean Title, No Accidents, No Rust, Smoggable and Currently Registered, 380 awhp (mustang dyno), 125k Miles, 5 speed Manual, All Wheel Drive, LSD Rear End, Grey Leather Sunroof, Tinted windows to help with summer heat, Pioneer radio with aux and Ipod integration, 10" Fusion sub with built in amp,
Working A/C and Power Steering (9 times out of 10 a modified car is going to have these stripped out for weight savings and/or because they were broken)
Maintenance performed within the last two years: Always used Royal Purple or Valvoline VR1 Racing Oil, New Battery, New Power Steering Pump, New Alternator, Full Rebuild on Engine Top End, New Head Gasket, New Ball Joints and Lower Control Arms (all 4 corners), New Front Axles, New ISC, New Weighted Leather Shift Knob OEM, Tokico Illumina Struts
Upgrades/Mods (from the intake to the exhaust): Injen air filter, Evo 8 MAF with translator for DSM connection, Custom 4" intake with bov recirculation fitting, Garrett GT3582 Turbo T4 compressor and T3 Turbine Housing (Flows 65lbs a minute and/or 830 cfm), Hallman manual boost controller, Punishment Racing Front Mount Intercooler, Cleanly cut front bumper for flush fitment, HKS bov, Rebuilt 1990 DSM N/T throttle body (better flow), Evo 3 Intake Manifold, AEM Fuel Pressure Regulator, Walbro 255 Fuel Pump, Low Impedance 1000cc Injectors, HKS 272 Cams, New valves and valve stem seals, EVO 8 springs and retainers (8,000 RPM Redline), Tubular Manifold T3 fitment (Ceramic Coated and Header Wrapped for under the hood heat reduction), Tial 38mm Wastegate Slim Design, Vent to atmosphere dump tube, Custom Alternator and Power Steering Heat Shield, 3" o2 housing, downpipe and HKS Hi-Power exhaust
The center differential has been upgraded to a 4 spider center. The clutch is an ACT 2600 with Street Disk. The head gasket is an OEM composite gasket with ARP L19 head studs. Those heads studs are no joke. Torqued to 90 ft/lbs and I would like to see someone try to blow this head gasket. Intake and exhaust manifolds were port matched for the head. It has new Avid Racing poly urethane motor mounts- CNC aluminum with inserts.
Currently she is tuned on Evoscan since the 98-99 DSMs have the blacktop ECU. It is the same tuning software that the evo guys use now. It has a 2 step set up tuned in, but that is really only for track use.
She made 380 AWHP and 311 Ft/lb of Torque on the Mustang Dyno at FFTEC. Will provide dyno print out with car. That dyno gives consistently lower readings than dyno jet types of dynos as well. Ask anybody that works there and they will tell you the same. Car is easily over 400 awhp if it was taken to a dyno jet. Currently boosting 25psi on pump 91 octane fuel. If you know anything about tuning cars, you should know that this means the turbo is not even stressing at these levels. Once you go e85 and turn the boost up, this car will have no problem making over 500 awhp.
The brakes are slotted and dimpled rotors with Hawk HP+ brake pads. Rims are ADR M-Classics. Tires are Hankook Ventus v4 es. There's only about 1,000 miles on the tires, rims and brakes.
It has a Mishimoto aluminum radiator. One slimline fan mounted in the engine bay and one mounted in front of the radiator and a/c condenser in order to provide clearance for the turbo. 60/40 water/coolant with Redline Water Wetter to help keep the car running cool.
Obviously no car is perfect. The (not so) bads are as follows: CEL comes on intermittently for a bad rear o2 sensor. The passenger side front fender is dented from when one of the balljoints gave out. (All the ball joints were replaced as a result of that whole issue.) You can see it in the pictures. I have a replacement fender and sidekirt cap to replace that though. Fender is the same color. Sorry I haven't had time to replace that, but I work two jobs now and there just aren't enough hours in the day.
New Link
