Cornfed4G64
- 215
- 1
- Feb 10, 2011
Lindwood,
Minnesota
How it all started!!
1998 RED
Auto GSX
Shortblock
2.4 g4cs .40 over 87.5mm
Manley H beams w/22 wrist pins
CP custom 9:5:1 87.5mm
Acl race bearings (main,rod)
Kiggly main girdle
Arp mains (line,honed)
BSE
AMS race shaft
Mighty max FF OFH
Maximal sandwich plate (external oil cooler)
Head
1G no porting
GSC springs/evo retainers
GSC S2
1mm over exhaust/intake valves (unknown brand)
L19 head studs
Cometic Custom MLS
Kiggly HLA regulator
Trans/drivetrain
Trans lab shift kit
Kiggly 6bolt in a 2G shift kit
Full line pressure mod
(Need to get trans in before I touch the end clutch)
LSD rear diff
Forced four shiftbox plus
Cooling
Mishimoto radiator with 2 slimline pushers mounted in front
Mishimoto overflow
B&M oil cooler -8an lines
B&M trans cooler -6an lines
Turbo/exhaust/intake
J pipe comp cover (stock appearing)
3076 billet wheel
Tdo6h4
FP 8cm hotside
Holset actuator
FP race mani
Punishment o2 w/external dump
Megan downpipe
SRS catback
FP 4" non recirc
Vrsf FMIC
9" k&n filter
Speed denisity (still need)
N/T throttle body
1G intake mani
Catch can setup
Tial knock off bov
Electronics/tuning
Ecmlink v3
AEM wideband
AEM boost -30to35
Autometer phantom
Oil pressure
Coolant temp
Trans temp
Volt
Greddy TT
Remote start/alarm
Fuel
255 hp walbro
BAP (if needed)
-6an lines from tank to rail
Fuel lab filter w/e85 filter
OBX fuel rail w/fuel press gauge
Fuel lab FPR with -6an lines
Fic 1100 high z
E85
Brakes/wheels/suspension
16" kosei k1s (metalic grey)
225/50/16 nitto nt555r
Stock GSX calipers
Slotted rotors
Hawk pads
Non/abs car
Jic coilovers
Full prothane motor mount kit
Interior
Black leather seats
Black dash
Black door skins
Black rear speaker covers
black carpet (DIY)
All other panels that were oem grey are being painted satin black
Custom triple gauge pod in place of center vent
Custom gauge pod where radio was
Black suede headliner
Exterior
Carbon hood
Carbon hatch
FAL poly carbonate hatch window
Sound detening removal. Works awesome when cold out peels right up
Still need to swap black belts in
Jeebus that was alot.
Plan is to get well into the tens (10.5-10.7) in almost full weight car
Ill keep updating as I go but car should be ready to start by early may. Just gotta cross fingers as my work schedule is getting busier.
1998 RED
Auto GSX
Shortblock
Kiggly main girdle
BSE
AMS race shaft
Mighty max FF OFH
Head
1G no porting
GSC S2
L19 head studs
Cometic Custom MLS
Trans/drivetrain
Trans lab shift kit
LSD rear diff
Cooling
Mishimoto overflow
3076 billet wheel
Tdo6h4
FP 8cm hotside
Holset actuator
FP race mani
Megan downpipe
SRS catback
FP 4" non recirc
Vrsf FMIC
9" k&n filter
N/T throttle body
1G intake mani
Catch can setup
Tial knock off bov
Electronics/tuning
Ecmlink v3
AEM wideband
AEM boost -30to35
Autometer phantom
Oil pressure
Coolant temp
Trans temp
Volt
Greddy TT
Remote start/alarm
Fuel
255 hp walbro
BAP (if needed)
Fic 1100 high z
E85
Stock GSX calipers
Slotted rotors
Hawk pads
Non/abs car
Jic coilovers
Interior
Black leather seats
Black dash
Black door skins
black carpet (DIY)
Exterior
Carbon hood
Carbon hatch
