1997 GS Spyder issues...
KARR
Mar 30, 2003
Car: A friend of mine's 1997 GS Spyder, M/T with 88K miles on it, stock.
I'm not sure if you guy's can understand my problem description but here it goes:
Problem..."Non-Smooth Idle":
-When at idle (700- 750 rpm's) you can feel the gases "stumbling" out
of the exhaust. Heres the best i can shortly describe this: It's seems
like its having trouble maintaining the feel and sound of a smooth n'
stable idle.
The car gives the impression of having initial symptoms of wanting to
turn off (die out), but it doesn't.
No electrical power is felt failing (Example- interior/exterior
lights do not dim, or go weak when when turned on while at idle), and
no idle surge occurs.
The other thing is that the "stumbling of gases" seem to minimize when
the air conditioner is turned on, and this ONLY happens at idle. It has
no CEL either.
Question...actually I have 2 of them:
1. What can be causing this non-smooth idling problem?
2. This one was also searched:
Can it be possible to manually (with your bare hands) depress and
compress a factory front '97 GS Spyder shock absorber (the black
one)? Or does this means that it needs to be replaced? BTW, it has
no leaks (the shock).
I ask because a mechanic told my friend that this was completely
normal. He said that they come with factory hydraulic shocks (??).
Aren't they supposed to be hard or impossible to be compressed with
the use of your hands, or at least resist the force you apply to it?
(The owner of the car was going to replace it but now he is confused).
Help will be greatly appreciated. Thanks again guys, in advance.
if you are taliking about just the strut w/o the spring, i believe you should be able to compress the strut. its the spring that is what you cant compress unless you have a macphereson (sp?) spring compressor or some tool like it. sorry i cant answer your other question. but someone will correct me if im wrong.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Message 702-741-6987.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $240 + shipping and PayPal fees* just replaced the upper bushing with...
  • For sale 4G63 Heads/ head parts
    Heads/ head partsNever ran ready to bolt up 1G head Ferrea dual valve springs/ retainers...
    • Dsm_canadian_mike
  • For sale 2g 2G Spare Tire Trim & Tool Pouch
    2G Spare Tire Trim & Tool Pouch $40 + shipping and PayPal fees* tool pouch has the tools...
  • For sale 2g 2G AWD Fuel Filler Neck
    2G AWD Fuel Filler Neck $65 + shipping and PayPal feesYou must be registered to see...
