frasergavin947
- 2
- Apr 11, 2021
Bandon,
Oregon
This thread is for the general discussion of the vehicle 1996 gsx 4g63t 7 bolt. Please add to the discussion here.
This would be the place to find some side skirts just take a look in classifieds at some point someone will have some. I've never heard of Godspeed coils, I went from Koni to Fortune Auto gas coilovers. Good to see your starting with maintenance first above all, ive been building mine for 3 years now the first 1 and a half years was spent on maintenance and preventative maintenance.Im open to all suggestions. Thanks on the compliment. It's currently in the shop right now at my house on the lift. Before I officially make her my daily driver I wanted all the gaskets and studs re-done and the new motor mounts because the ones that came in it were probably the factory set ones and they look like pancakes sitting in there... That's how loose they were! And every time it shifts it just shakes so I didn't want to run a risk you know and that's why currently she's sitting down right now. So far since taking her home she has received a new valve cover gasket a new exhaust manifold gasket all new motor mounts a fresh mobile one full synthetic oil change all new fluids.
we got a front and rear camber kit and godspeed fully adjustable coilovers we're just basically replacing everything that needs to be replaced right now just to have it you know running clean she runs really clean but at the same time we just want to make sure everything's done right I'm at that point in my life where I'm able to finally do the things I want to do and why do things wrong when you can do them right. One thing I've been having trouble finding is the oem side skirts. My whole style to this build is like JDM/sleeper build.
