1. Join the Community!
1995 gsx eclipse
Posted by Jonathan1019, May 17, 2019
Please Support Kiggly Racing
Please Support Feal Suspension
  1. Jonathan1019
    Jonathan1019 Probationary Member
    4
    Joined May 17, 2019
    Denver, Colorado
    So I have a 1995 gsx eclipse and my engine light turned on because it saying that canister purge valve is not working and it’s running rich in gas but I oreder the part and got it and I can’t find for the canister around I checked in the passenger side under the intercooler and under the battery and on the driver side and I can’t find it I need help
    Street Build 75  3
    1995 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  2. jstoned1
    jstoned1 Probationary Member
    25
    Joined Aug 14, 2010
    oak hills, California
    Street Build 677  5
    1991 Mitsubishi Eclipse GSX
    12.5 @ 115 · 1G DSM
    Loading...
  3. Jonathan1019
    4
    Joined May 17, 2019
    Denver, Colorado
    They don’t have the solution but it’s the same problem
    Street Build 75  3
    Loading...
  4. ThunderChild
    ThunderChild Supporting VIP
    2,524
    686
    Joined Jan 5, 2012
    Rathdrum, Idaho
    I believe the purge valve is actually on the upper firewall cowl, just behind the intake manifold.
    Upper right corner of this pic, between the fuel pressure solenoid and EGR solenoid.
    Edit: pardon, I see you said the actual valve itself. Should be under the battery tray, passenger rear of the engine bay close to the firewall, attached to the charcoal canister.
    If not there, this thread may help you look for some of the possible locations.
    https://www.dsmtuners.com/threads/where-is-my-charcoal-canister-is-there-one.411273/
    Street Build 166  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    266  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 793  7
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    Street Build 1K  1
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
  5. Jonathan1019
    4
    Joined May 17, 2019
    Denver, Colorado
    I checked under there and there was no sign of the canister, is there any pictures of the location or something cause I seen that it was around there but i checked and it wasn’t there and I’m kinda starting to believe I don’t have it
    Street Build 75  3
    Loading...
  6. ThunderChild
    2,524
    686
    Joined Jan 5, 2012
    Rathdrum, Idaho
    You'd know the canister if you saw it, occupies alot of space and is kind of rounded rectangular. Check in the front driver's side, behind the bumper cover in front of the wheel.
    Street Build 166  3
    266  8
    Street Build 793  7
    Street Build 1K  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  7. jstoned1
    25
    Joined Aug 14, 2010
    I’ve also read it could be near the fuel tank or even inside the fuel tank.
    Street Build 677  5
    12.5 @ 115 · 1G DSM
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com White Shed Speed
