1992_Talon_tsi
- 384
- 2
- Dec 20, 2009
MIAMI,
Florida
Hello im heaving some thoughts on the car i bought and i would like if you guys could describe more or less of whats going on. Its a 1995 GST freshly built 7BOLT BLOCK with eagle crank, eagle rods & bearings, je pistons, arp hg & head studs. Currently the car its not running have some issue with the clutch and havent got around to turn it on. Today i pulled the oil pan to check how the bottom end was doing and when i drain the oil i found it dint have the clear color it looked greyish pictures of the pan below, the i check the rods all look good but one of them looked kind of burn also pictures above the other 3 looked ok, i would like to know whats happening here?
[/ATTACH][/ATTACH]Attachments
