drparanoid
- 0
- Dec 29, 2009
Aurora,
Illinois
1995 Eclipse GST (for part out) Tons of performance parts. Pickup Only
I had a garage when I started the project but moved and was never able to complete the project. Life got in the way. This car has not run in a few years all of the value is in the parts, below is a list of installed parts. The body is rough I won’t lie however I have a crazy amount of performance parts. Engine was re-manufactured by Windy City Engineering in Chicago shortly before I moved. Title is clean. Selling the whole car would need to be towed.
Located in Aurora, IL. Accepting reasonable offers Email, PM, call or text
Email: [email protected]
331-575-5914
Engine
1G 6 bolt main engine 4G63 2.0L
Balance shaft elimination kit
Wiseco Forged 85.50 mm pistons 9.0-1 compression
Eagle 6 bolt H-Beam Rods ARP hardware
Remanufactured 1G head with stainless valves
Kelford 272 cams
Supertech Valve Springs
Revised Lifters
Fidanza Adjustable Cam gears
Acl rod and main bearings
ARP L19 Head Studs
ARP Main Studs
Clutch / Flywheel
ACT 2900 6 Puck sprung clutch
Lightweight Fly wheel
Intake / Turbo
1G JMF Race manifold sheet metal
S90 70mm throttle body
FIC 950 CC Low-Z injectors
FIC Fuel Rail
1G BOV
Forced performance cast turbo manifold
STM recirculated O2 housing
Blouch dominator turbo gt30 wheel
VRSF 2G front mount intercooler
FWD thermal R&D exhaust
Fuel Labs fuel pressure regulator
Electronics
DSM Dynatek arc 2 complete with installation kit. Denso Pencil Coils
AEM wideband O2 sensor
1G CAS
EVO 8 MAF
Tires / Wheels
Hankook Evo 12 255 40r 17” Tires Barley used / Drag 17” wheels
Front Brakes
RTM Racing VR4 4-Piston conversion kit (complete with brackets hub centric rings and upgraded lines.)
EBC dimpled 13” Mustang Cobra rotors
Hawk HPS Pads
Rear Brakes
Evo 8 Brembo 2 piston rear calipers / Slotted rotors.
Other
Performance Aluminum Radiator
Tein Coil over’s
2 Valve Covers one polished with welded AN Fitting (installed on car), Blue powder coated cover not installed.
Other Available Parts (would sell with the car for the right price)
I have a few parts I am selling separately however with the right offer I may include them. I have pictures of all the parts listed below and would be happy to send them if request. since these parts are not currently installed I may sell them separately.
HX40 turbo / Authentic Holset Center section / KTS Billet Wheel 60X86 / Authentic Holset 12 blade turbine / BAE compressor cover / BEP DSM Stainless Turbine Housing.
ECM Link V3 Complete / 1995 ECU / Socketed by ECM Tuning / Speed Density Cable / Boost Control Solenoid
AWD conversion parts / 2G manual transmission, transfer case, rear differential, axles, drive shaft, rear control arms spindles, fuel tank. Basically 95% of what you need to convert to AWD (I don’t have the fuel tank hangers or heat shield, or the rear differential mounting bolts.)
331-575-5914
Engine
Kelford 272 cams
Revised Lifters
ARP L19 Head Studs
ARP Main Studs
Clutch / Flywheel
Intake / Turbo
FIC Fuel Rail
1G BOV
Electronics
1G CAS
EVO 8 MAF
Tires / Wheels
Front Brakes
Hawk HPS Pads
Rear Brakes
Other
Tein Coil over’s
