Thedominator82
- 3
- Jul 13, 2016
Puyallup,
Washington
2g dsm turbo awd. I’ve owned the car since 99 and it’s time to move on to a different project. Lots of aftermarket parts most of which have less then 1000 miles because I hardly drive the car.
located in Puyallup Washington
Forced performance red turbo
Ets 3.5 inch intercooler
Forced performance intake
Forced performance manifold
Forced performance fp2 cams
Fuel injector clinic 1150cc injectors
Fuel injector clinic fuel rail and AN lines
Tial blow off valve
Dynatek arc 2 ignition
Aeromotive fuel pressure regulator
Fuel lab fuel filter
Jmf small battery kit with odyssey battery
Fluidyne radiator
Ecmlink tuning software running on speed density so no maf sensor.
10an fittings welded on valve cover for crank case pressure
Powder coated valve cover
ARP headstuds
STM tuned O2 housing with atmospheric dump tube
Calan catch can
Calan overflow tank
Aem methanol injection
Turbo xs boost controller
Innovate motor sports wideband a/f gauge
Auto meter boost gauge
B and M short shifter
Led shift light
Sparco sprint seats
Cipher 5 point harness and harness bar
18” Enkei PF01 powder coated black
Hankook Ventus v12 evo 2 tires
Vis racing body kit
Carbon dimensions carbon fiber hood
Aerocatch hood pins
Carbonetics asl carbon fiber deck lid
RRE downpipe with race pipe
HKS Hi Power exhaust
Southbend clutch
ACT aluminum flywheel
Evo Wicked white paint job
Maintenance within 500 miles
Mitsubishi oem head gasket
Gates timing belt
Water pump
Alternator and power steering belts
Brake pads and rotors
Spark plugs and wires
Extra parts included for the asking price
6bolt block and crank
6 bolt rods
2g complete head
Jmf coil on plug set up
Cons
No headliner
Sunroof doesn’t work
Passenger keyhole for door lock doesn’t work
Passenger window doesn’t roll up from drivers side only passenger side.
Tial blow off valve
Fluidyne radiator
ARP headstuds
Calan catch can
Calan overflow tank
Led shift light
Sparco sprint seats
Vis racing body kit
Aerocatch hood pins
Southbend clutch
Gates timing belt
Water pump
6 bolt rods
2g complete head
Cons
No headliner
