DarthBulk
- 644
- 9
- Jun 11, 2003
Waukesha,
Wisconsin
I have a 1994 Talon with a professionally rebuilt 4G63 6-bolt engine and head. It was driven approximately 2000 miles on the rebuild, then I took the body apart to do some body work. The rust is all repaired, but I did not get the car body put back together, as we started a family, so the car has been sitting a few years. Basically I am selling this as a built engine with associated parts, and get the car for free. You can put it back together or take the engine and put it in your project.
The engine has Mahle pistons, Brian Crower BC1 cams, tubular exhaust manifold, brand new genuine Mitsubishi EVO III 16g turbo, aluminum radiator, silicone hoses, prothane bushings on front control arms and motor mounts, new clutch master and slave cylinders, ACT 2100 clutch. Air cleaner and all engine brackets and control arms were sandblasted and powder coated. full stainless steel exhaust from downpipe back to muffler. I am sure I am missing something, as there was a lot of work done. As you can see from the pictures, the car is a bit dirty from sitting, but the engine will clean up nice. The transmission is good, and all wheel bearings, tie rod ends, and ball joints were also replaced on the car.
The car also comes with 2 rust free doors and rust free front fenders. Asking $3500 OBO
