1fastBU
- 0
- Apr 4, 2019
Richmond,
Kentucky
Looking to move my DSM, 1993 Talon tsi awd 5 speed. $6500 obo
This is a list of KNOWN modifications:
- FID2000cc Injectors
- Fuel lab external fpr
- BC272 cams
- Adjustable cam gears
- 20g turbo (freshly rebuilt)
- Buschur front mount
- Aluminum radiator with single fan puller
- ECMlink v3 updated to latest firmware
- Tuned on e85 (20psi)
- electronic boost solenoid wired into ecmlink
- rx7 FD wheels
- ARP rear studs (have fronts new in package but not installed)
- brand new toyo extensa hp2 tires
- tubular mustache bar new not installed
- upper and lower DIY rear adjustable control arms not installed
- ground control coilovers (will need new struts in front as one is noisy when hitting bump)
- ARP head studs
Ive recently put an ac condensor and lines back in the car with a pusher fan and wired everything up and tested the circuit by jumping the low pressure switch and everything works as it should just needs the ac bracket, tensioner and compressor installed which is all included. the ac compressor is new from the parts house. The car does not have emergency brake cables, but both sides new will be included. Car has recently (less than 1 year ago) had fresh paint.
I was told by previous owner the car had a built motor. I cant say for certain whether it does or not, but I didnt chance it and tuned it safely on 20psi. With some more digging and maybe a boroscope a person could tell, but i have never looked into it. I pulled the valvecover off and verified which cams were in it and the ARP studs were in it, thats as far as I have went. Outside the fact that its on E85 and not readily available, i'd drive the car anywhere. Its always been reliable for me, and never runs hot. Just looking to move on to a different project.
The car is notchy going into second gear, but every other gear is butter smooth. No lift shift is wired up and working properly. Car does come with an extra 6 bolt motor completely disassembled, transmission and transfer case all out of a 93 talon.
P.S. sorry for the terrible rear tint and the old steel wheels i had on it to move it around. Dont hate me for that
Located in Richmond, KY 40475 pickup only!
- BC272 cams
- rx7 FD wheels
- ARP head studs
