1. Join the Community!
Sold 1992 Mitsubishi Eclipse GST 122K , Built - MA
Posted by Aethro, Jul 3, 2020
Please Support STM Tuned
  1. Aethro
    Aethro Probationary Member
    9
    Joined Jun 21, 2018
    North Adams, Massachusetts
    1992 Mitsubishi Eclipse GS-T
    FWD - 5 Speed
    122k Miles less than 10k on rebuild
    Rebuilt/Resurfaced 6 Bolt Head and Block
    Wiseco HD 1400 evo Pistons 9:1 ,Tool Steel Pins .040 over
    Manley H Beam Rods 6 bolt journals to evo piston
    ACT Street lite Flywheel
    XTE Stage III Clutch
    Tubular Exhaust Manifold
    Megan racing 3" SS down-pipe
    3" SS High Flow CAT
    Mamba Adjustable Spring Waste gate
    Cometic MLS Head Gasket
    ARP Head studs
    ARP Main studs (line bore/honed)
    ACL Tri-Metal Race Bearings
    Topline revised lifters
    New Oil pump/gears & BSE
    New Timing pulleys and Tensioner
    New Mitsubishi Knock Sensor
    Gates Racing Kevlar Timing belt
    HKS Clear Timing Cover
    Mitsubishi EVO III 16g Turbo @25 PSi
    Huge Front Mount Intercooler
    All Aluminum 3" piping
    K&N 3" Aluminum Custom intake
    Silicone Couplers w/ T-Bolt Clamping
    Greddy FV Blowoff Valve
    PTE 780cc Injectors
    Walboro 255 Rewired Fuel pump
    Aeromotive Fuel Pressure Regulator
    Fuel Lab Aluminum filter with AN SS lines
    Complete Snow Performance Methanol injection kit
    Snow Performance Stage -2 Boost gauge/meth control
    3 Gallon Sumped Meth injection Tank
    DSM Link v3 with Cable
    (tuned By Kevin Jewer Remotely)
    Socketed re-Caped EPROM Ecu
    MAP sensor Conversion Harness
    Variable Boost Control Solenoid
    Innovative Wide band O2 and Gauge
    Magnecore Spark Plug Wires, BPR-7ES Plugs
    EGR Block off
    Optima Red Top Battery (Winter stored and maintained)
    Custom Aluminum Battery Mount Plate
    Full Silicone Coolant hoses
    Dual core Aluminum Radiator
    Mishimoto Aluminum Radiator Shroud
    Mishimoto Slimline fans
    iNjen Aluminum Spark Plug Cover
    HKS Radiator Cap
    HKS Oil Cap
    New Koni Yellow Front and Rear Adjustable Struts
    H&R Sport 1"Drop Spring Set
    New Driver/Passenger Axle/CV
    New Front And Rear Wheel Bearings
    New Sway bar Links and tie rod ends
    New GT Brake Rotors
    Re-man. Dual Piston Brake Calipers
    17x8 RPF1 Gold Rims with 225/45 Tires
    NRG EVO Carbon/Leather Steering Wheel
    NRG Quick Release Steering Wheel Hub
    7" Android Dual Din Stereo GPS, TPMS,
    Light Weight Sub woofer
    1080p Dash and Backup Cameras
    Wet Okole Custom Neoprene Seat Covers
    Custom Black Leather Headliner
    LED Parking and Directional Bulb Conversions
    Sold
      File size:
      123.3 KB
      75
      File size:
      83 KB
      76
      File size:
      79.8 KB
      76
      File size:
      77.9 KB
      79
      File size:
      714.9 KB
      58
      File size:
      748.4 KB
      59
      File size:
      652 KB
      60
      File size:
      772.6 KB
      59
      File size:
      763.1 KB
      110
      File size:
      398.5 KB
      106
      File size:
      839.9 KB
      105
      File size:
      710.8 KB
      109
      File size:
      663 KB
      59
      File size:
      546.2 KB
      58
      File size:
      679.4 KB
      59
      File size:
      691.6 KB
      60
      File size:
      814.7 KB
      58
      File size:
      630.2 KB
      58
      File size:
      978.4 KB
      108
      File size:
      859.4 KB
      57
      File size:
      849.2 KB
      109
    345  3
    fwd · manual · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
