15143226
- 39
- 7
- Jan 13, 2019
Sheboygan,
Wisconsin
i have a 1992 mitsubishi mirage that has been awd swapped with all parts needed for 4g63t and w4a33 trans to drop in and go. i have a built motor with RnR aluminum rods, ross pistons, kiggly girdle with billet main caps,virgin crank, king bearings and 10.5 to 1 compression ratio. still 2.0 liter. i have a w4a33 trans a translab shift kit and kiggly 6 friction clutch pack with but not installed. an ecm link ecu everything ready to go for speed density with a brand new sensor and bung already on the intercooler piping. shell is setup for nos and battery is relocated to trunk. drivetrain is setup for around 800hp with a 4 bolt rear. there are a lot of extra parts including a competition twin diac clutch and manual flywheel with less than 100 miles on it in case you want to go manual. shell is rust free. i have a custom jm fab twin scroll t4 manifold about 4 weeks out with dual mvs 38mm wastegate flange. the only thing this build needs is a downpipe/02 housing a turbo and the 2 wastegates and to have the engine,trans, and ecu installed to be a running car. i have put over 1200 into this build so far and i can get reciets if you want. i also am in contact with the person i bought the shell from if there is any info i cant answer. im putting feelers out there and wont accept anything lower than 10,500 for the build. i dont want to sell but i have run into a block as this is taking so much of my time and money and now i cant find anyone to build the trans with the parts i have without spending 2400 on a total rebuild of the trans. like i said i dont want to sell but i am putting out feelers if i dont get the money i am going to continue to build it. (more photos coming soon)
