stevetrbp
- 127
- 0
- Feb 21, 2003
I have a t3/t4 running 18lbs with vpc 550s 255 pump and 93 octane. Is this a safe level for pump gas? It dosent seem to be running lean, plugs are not white. I have no wideband or anything
Originally posted by stevetrbp
It was only like that for one day, but I can dyno tune it on my freinds dyno once I get a v.c elilminator. I know there isnt that much tuning you can do with the vpc, but will dyno tuning with wideband be enough for now till I can afford more stuff?
550 chip, I know that using a afc will break down the fine points that I need, I was just wondering if tunning it the way it is right now will be safe enough till I can pick up some more hardware. Im sure it will, just wont be as fast as it should be. Thanks for everyones help. I was thinking of selling my vpc and using some other method of tuning, or should I keep it and just get a afc? Vpc costs alot, would something like a e-manage be better to use than a vpc and afc?
