- Thread starter
- #26
GSXftw
- 381
- 78
- Dec 16, 2009
Medford,
Oregon
So had another very productive night. Put in a good 7 hours. Im on break before winter term starts so using it to my advantage. Not bad for 10+ years out of school huh?
First off, I realized I forgot to stake the nuts on the trans last night. Mightve been okay with 105 ft lbs and red loctite, but Ive had them back off and take out an end cover before. So broke back into it, staked them, back together. Then... I removed the water cooled oil filter housing, scraped gasket surface, and got ready to do the FFOFH
I went ahead and ported out the oil relief hole.
Then I pulled the water pipe and welded up the water outlet.
The southbend is looking real good for so many antilag launches...Im impressed.
I switched the sensors around on the OFHs, as well as the T-stat housings. I plan on using my DSM radiator, so leaving the DSM Tstat housing with a cap. Looped the coolant lines on it, and boom set up for external air cooling. After removing/installing dowells, and installing my three speed scattershield, it all came together
Looks good if I say so myself
I think I am finally ready for a bay to do work on the car.
