1. Join the Community!
16g on 93 (proper tune before e-85)
Posted by razrman8, May 13, 2012
Please Support JNZ Tuning
  1. razrman8
    razrman8 Proven Member
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    My GSX is currently running 93 octane fuel. I will soon be converting to e-85. But, what I want to make sure of is that my 93 tune is good before I go switching over to e-85. I want to have everything dialed in the way it should be before the conversion. I have attached a log from the car and all mods are up to date in profile. Any input is appreciated. I am still learning the whole tuning thing. Thanks for your input.
    1K  0
    1999 Mitsubishi Eclipse GSX
    309.6 whp · 273.37 lb/ft · 2G DSM
    Loading...
  2. jrohner
    jrohner Proven Member
    2,557
    9
    Joined Sep 25, 2004
    Willmar, Minnesota
    You'll hopefully be throwing away your pump gas tune anyways when you switch to E85, so why does it matter?
    2K  0
    1991 Mitsubishi Eclipse GSX
    11.415 @ 119.59 · 1G DSM
    4K  0
    1998 Mitsubishi Eclipse GSX
    414 whp · 459 lb/ft · 2G DSM
    Loading...
  3. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    I wanted to make sure I had everything ironed out with pump before. Any things I need to look for.
    1K  0
    Loading...
  4. asrdave
    asrdave Proven Member
    192
    Joined Aug 6, 2008
    Bergenfield, New Jersey
    do you have a fuel pump done? only reason I ask is because your afrest and wideband are way off from each other
    356  0
    1995 Eagle Talon TSi AWD
    · 2G DSM
    Loading...
  5. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    No, I have not done a fuel pump. It's stock
    1K  0
    Loading...
  6. asrdave
    192
    Joined Aug 6, 2008
    you need your pump done, because you are leaning out hard
    356  0
    · 2G DSM
    Loading...
  7. DSMDEMON93
    DSMDEMON93 Proven Member
    202
    Joined Feb 18, 2009
    San Jose, California
    Your IDC pegs at 104%! A reccomended ~80% is the ballpark you should be aiming for.
    521  0
    1995 Mitsubishi Eclipse GSX
    · 2G DSM
    Loading...
  8. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    Yeah, I see. It's hard to keep them controlled when the boost just continually creeps the more you lay into it.
    1K  0
    Loading...
  9. yukiz
    yukiz Proven Member
    180
    3
    Joined Jun 17, 2009
    Bay area, California
    your wideband is showing too lean 13.6 @ wot is way too lean......
    Street Build 3K  23
    1998 Mitsubishi Eclipse GST
    manual · 2G DSM
    Loading...
  10. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    Need more fuel.
    1K  0
    Loading...
  11. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    I installed my FIC 1150 injectors today. Here is the first log of them at idle. I am going out to get a cruise log now. I am noticing that AFRest isn't matching with my wideband.
    1K  0
    Loading...
  12. knochgoon24
    knochgoon24 DSM Wiseman
    4,753
    68
    Joined Jan 29, 2008
    Troy, Michigan
    Are you going to try running E85 on the stock fuel pump? Don't think so.
    2K  1
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    1K  0
    1991 Eagle Talon N/T
    manual · 1G DSM
    2K  0
    1996 Mitsubishi Eclipse GST
    automatic · 2G DSM
    2K  0
    1997 Eagle Talon TSi AWD
    13.869 @ 95.090 · 2G DSM
    Loading...
  13. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    No, I am not running e-85 on the stock fuel pump. I have a Denso 300 that I will be putting in. After just installing my new injectors, that is the only thing left to install before the coversion.
    1K  0
    Loading...
  14. jrohner
    2,557
    9
    Joined Sep 25, 2004
    Willmar, Minnesota
    Just seeing a 104 or higher IDC is proof enough that it doesn't mean much; how can you have more than 100% of something? Some even see much higher than 104.
    I've ran it on the stock pump AND the stock injectors. Yes the boost had to be pretty low.
    You'll be happy to have boost creep once you switch to E85. I wish I had boost creep instead of boost taper.
    2K  0
    4K  0
    Loading...
  15. razrman8
    910
    20
    Joined Jul 7, 2010
    Troy, Missouri
    There is no longer high idc.
    1K  0
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
